Kai wrote:Well, yes, they are a tight fit.
I got mine in by whetting both the caliper bore and the piston with brake fluid. Then force the pistons into the caliper with a twisting motion. Be careful not to damage the o-rings; this will invariably result in a leak.
Best to be prepared for a failure or two before you get the hang of it, so get yourself a small supply of spare o-rings from Sonex.
Also, take care to align the piston properly with the bore when inserting- if not you could nick the piston. A grade in the piston rim could cause scratches in the bore causing leaks.
Thx
Kai
pfhoeycfi wrote:
I wondering if the solution is to install a thin washer between the brake body and the bearing dust washer to give just a little room between the puck and the disc allowing the axle nut to tighten the assembly against the brake body and not the brake pucks?
