pappas wrote:Replacing it isn't really that much cost or work. Match drilling is an easy skill to acquire and one you definitely need to have. You will use the tool above often and it will keep you from oversizing any rivet holes you need to drill out.
Bryan Cotton wrote:If I was going to match drill it, I'd clamp the new longeron to the skin and just transfer the holes. If you really wanted to be crazy about it, transfer the holes from the bent longeron to some cheap home depot 1/8" flat stock, and then transfer those holes to the new longeron.
There is nothing wrong with being crazy about it, but it is probably not a requirement.
