engine mount
engine mount
Postby pfhoeycfi » Tue Mar 10, 2020 8:02 pm
Double dipping...
I haven't done installed anything on the firewall. Is it too early to install the engine mount or will I end up taking it off, putting it back on several times (like every other part)?
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: engine mount
Postby Rynoth » Tue Mar 10, 2020 10:22 pm
I mounted my engine mount prior to planning my firewall, and it was helpful to know where the interferences were in doing so. I never removed the mount to complete the rest of the firewall forward as it would have meant pulling the gear legs off as well (tailwheel.)
I did mount the engine to the mount on/off a couple times.
http://www.rynoth.com/wordpress/waiex/2 ... ttery-box/
Re: engine mount
Postby wlarson861 » Wed Mar 11, 2020 12:13 am
I'm with Ryan, you actually need the engine mount in place in order to locate the parts like coils, battery etc.
Bill Larson
N861SX
wlarson861
Re: engine mount
Postby pfhoeycfi » Wed Mar 11, 2020 4:30 pm
great...thank you
Peter Hoey
pfhoeycfi
Re: engine mount
Postby pfhoeycfi » Fri Mar 20, 2020 6:38 pm
I'm installing the engine mount and the distance between the bottom holes of the mount are just a fraction more than the distance between the holes in the lower blocks on the airframe. My overall width is dead on so I'm not sure what's off. That's pretty much a fixed distance. Anybody experience this and what was the solution? It's very slight perhaps between a 1/32 and a 1/16th but its enough to keep me from inserting the last bolt. I tried playing around with inserting different bolts first etc. I dont want to run a bit thru it and want to save trying heat for last. Any thoughts?
Peter Hoey
pfhoeycfi
Re: engine mount
Postby GordonTurner » Fri Mar 20, 2020 8:14 pm
Picture?
Re: engine mount
Postby dirkverdonck » Sat Mar 21, 2020 4:08 am
Hi Peter,
Had the same issue with my UL Power engine mount on my Waiex-B #0036.
Sonex sent me an aluminium insert to plug the original hole, I then refitted the mount and redrilled a new hole using the engine mount as a drill guide. ( mine was about a half bolt diameter off )
I first adjusted the hole so the plug didn't fit and then heated the airframe part with an electric paint remover and tapped the plug in to obtain a nice fit.
Dirk Verdonck
Leffinge, Belgium
Onex #117
dirkverdonck
Re: engine mount
Postby pfhoeycfi » Mon Mar 23, 2020 5:21 pm
Hi Dirk,
That's what I'll do. Sonex doesnt have the plugs I'll order some round stock from spruce.
Peter Hoey
pfhoeycfi
Re: engine mount
Postby richd » Fri Nov 19, 2021 8:07 pm
dirkverdonck wrote:Hi Peter,
This worked for Me: Sonex sent me a custom made dowel that fit perfect. I probably went a little overboard on making the whole perfect, but it is one of the most important holes.
Yours truly, a meat guy in a parking lot.
Steps to move engine mount Bolt hole.pdf
(2.25 MiB) Downloaded 242 times
richd
Return to Sonex-B / Waiex-B
