mike.smith wrote:I used screws and nuts for the canopy. The hollow bows seemed an impractical material to tap, as there is hardly any material for the screws to hold onto. I figured with all the in and out of the screws during fitting, I'd just end up stripping the holes. The screws and nuts were much easier to work with.
radfordc wrote:When it comes to tapping small holes this tool is very handy. Rather than using a normal tap handle, instead make a small "tap disk". Just a disk of aluminum drilled to fit the tap shank and a set screw from the edge to lock it in place. With this tool you have better control of the torque applied to the tap and less chance of accidentally applying side loads and snapping the tap.
pfhoeycfi wrote:Has anyone found a safe threadlocker to use on the canopy screws?
