lower forward skin
lower forward skin
Postby pfhoeycfi » Mon Nov 11, 2019 7:27 pm
I installed and riveted the lower forward skin, not the aft. I have yet to rivet the glareshield, install the gas tank or rig the wings and I now think riveting that bottom skin was a bad idea. I had checked w the factory and they just said to go ahead and rivet per the plans.
any thoughts on this? will I end up drilling out those rivets and pulling the skin to get at stuff?
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: lower forward skin
Postby Bryan Cotton » Mon Nov 11, 2019 9:00 pm
It is pretty awesome to be able to sit on the floor and work on stuff under the panel or in the forward wing roots. Neither of my skins are riveted yet.
Postby Concorde » Tue Nov 12, 2019 12:27 am
As long as you don’t rivet the glare shield you should be fine. I riveted mine before rigging the wings after talking to Sonex and some other builders.
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby Rynoth » Tue Nov 12, 2019 12:42 am
As a Waiex-A model builder I was glad I didn't rivet the forward fuse bottom skin until late in the project for ease of access, but don't believe it would have made anything impossible to do with it riveted. I imagine B models are similar but different... you may have given yourself some extra work (or not) by riveting it now, but by no means should it prevent progress going forward.
Postby sonex1566 » Tue Nov 12, 2019 7:08 am
I riveted mine on as per the plans and regretted it many times. I think Jeff Shulz has a picture of him squashed in under the dash. I tried that and almost needed the fire brigade to get out. Leave it flecked for as long as you can.
Richard
Scratch build Sonex
Std gear, dual control
Jabiru 3300, Sensenich prop
19-8776
http://www.sonex1566.com
sonex1566
Postby DCASonex » Tue Nov 12, 2019 10:19 am
The single center stick gives more access under the panel from inside the cockpit, but for some, even that will be too tight. That would have been true in my case were i an inch taller. The old lowered seat option, which makes for a deeper (longer front to back) seat, should also have provided a bit more room to maneuver ones torso under the panel. (I am not using that.) Still not a lot of fun, better to leave bottom panel off. But also need to remember that at some point after all is done you will still need to get back under there occasionally.
Postby pfhoeycfi » Tue Nov 12, 2019 12:10 pm
Thanks for the reply's. yes I crawled up under the glare shield to drill the longerons. I cant imagine what it will be like with the tank in place or even putting the tank in place. What concerns me the most though is getting at the nuts for the bolts that go thru the side skins and the upper engine mount attach fittings. That's one of the last things to do once the glare shield, tank, skirt are in place...
I do have a good chiropractor on call...
peter
Peter Hoey
pfhoeycfi
Postby pappas » Tue Nov 12, 2019 6:11 pm
I did not rivet the firewall or the aft fuselage skin until the last possible moment. That made rigging the wings and accessing things under the tank area much easier for me. I learned that from not doing it with the first Waiex I built.
The wings were rigged long before I hung the engine. You only need a fuselage in the boat stage to rig wings.
Lou Pappas
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Return to Sonex-B / Waiex-B
