Flap Mount Block
Posted: Fri Jul 05, 2019 6:21 pm
The flap drive tube is supported by the flap mount blocks which are bolted to the airplane with AN3-21 bolts. Can anyone recommend a torque value for these bolts. The tube is level & true etc but it seems that if I go past 20 on the T wrench it gets stiff..rotatable but stiff. The blocks are made from Delrin and I'm wondering if this stuff compresses. Tube is cleaned and lubed. I even put small alum foil shims between the blocks.
Any thoughts/recommendations would be appreciated.
peter
SNB0021
Wings, Tail, Control Surfaces, Tailcone done...getting ready to make something else twice.
peter
SNB0021
