Flap Mount Block
Flap Mount Block
Postby pfhoeycfi » Fri Jul 05, 2019 6:21 pm
The flap drive tube is supported by the flap mount blocks which are bolted to the airplane with AN3-21 bolts. Can anyone recommend a torque value for these bolts. The tube is level & true etc but it seems that if I go past 20 on the T wrench it gets stiff..rotatable but stiff. The blocks are made from Delrin and I'm wondering if this stuff compresses. Tube is cleaned and lubed. I even put small alum foil shims between the blocks.
Any thoughts/recommendations would be appreciated.
peter
SNB0021
Wings, Tail, Control Surfaces, Tailcone done...getting ready to make something else twice.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Flap Mount Block
Postby Rynoth » Fri Jul 05, 2019 10:12 pm
pfhoeycfi wrote:The flap drive tube is supported by the flap mount blocks which are bolted to the airplane with AN3-21 bolts. Can anyone recommend a torque value for these bolts. The tube is level & true etc but it seems that if I go past 20 on the T wrench it gets stiff..rotatable but stiff. The blocks are made from Delrin and I'm wondering if this stuff compresses. Tube is cleaned and lubed. I even put small alum foil shims between the blocks.
peter
SNB0021
Hi Peter, this doesn't answer your question but I'm wondering, did you remove the powder coat from the tube where it passes through the blocks? You may have meant this when you said it was "cleaned and lubed" but just want to be sure. The powder coat can cause gumming/binding.
That said, as long as the block halves are pressed together such that they wont be wobbly or leave a gap for the tube to work into, the nuts just need to be tight enough for the nylock to be fully engaged and secure the blocks. The bolts aren't subject to rotation and shouldn't be going anywhere. If I were to choose one of the bolts to be tighter than the other (for ease of movement), the forward bolt on each block is where aerodynamic pressure is going to be most forcefully applied so I'd want to be sure the block is tightest on the forward side.
Another option would be to just sand out the holes in the blocks to make them a little bit bigger, I think I did this several times before I was happy with the fit.
Postby pfhoeycfi » Sat Jul 06, 2019 9:50 am
Yes I had taken the coating off will a torch. I'll try your suggestions. I wasn't sure about sanding the delrin block given how smooth it is to begin with. I was prob overtightening...
Thank you,
Peter Hoey
pfhoeycfi
Return to Sonex-B / Waiex-B
