Sonex B Counterbalance
Postby pfhoeycfi » Tue Jan 08, 2019 4:32 pm
Where the counterbalance plates exit the front of the aileron there is a series of rivets required along the sides of the plates and then there are 4 rivets that go thru the hinge, the skin and into the counterbalance ribs. I'm curious how builders have been setting these rivets, especially the 4 mentioned since the plates are blocking access...meaning I cant get the rivet gun or any of my hand rivet pullers anywhere near the right position to pull the rivet because the plates are in the way.
The rivets along the side of the plates wont be easy but they are do-able...its the 4 thru the hinge that have me stuck. I used a 12" bit to drill those holes so that the drill would be clear of the plates.
any advice would be appreciated.
thanks
peter
SNB0021
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Sonex B Counterbalance
Postby Concorde » Tue Jan 08, 2019 5:54 pm
Can you post a picture ?
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby Bryan Cotton » Tue Jan 08, 2019 7:05 pm
Check out this tool thread:
viewtopic.php?f=34&t=2345
It has this link:
viewtopic.php?f=43&t=2300&start=10
Postby pfhoeycfi » Wed Jan 09, 2019 5:56 am
Bryan Cotton wrote:Check out this tool thread:
It has this link:
That's exactly what I was talking about. Thanks. I had updrilled all the parts and disassembled only to discover that I drilled those two inside holes too close to the plates ruining the support bracket on the other side of the skin. Not sure how to recover from this thinking I should have stuck with triathlon....prob need to order more parts and. start the aileron over
Thanks...
Peter Hoey
pfhoeycfi
Postby Spaceman » Mon Jan 14, 2019 9:39 pm
That little PRG 410 rivet puller is the most useful thing I've bought! I found one on ebay for like $8 and it has been a lifesaver. I don't even know how you could build this plane without one.
https://www.ebay.com/sch/i.html?_from=R ... 0&_sacat=0
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Return to Sonex-B / Waiex-B
Users browsing this forum: No registered users and 33 guests
