Wing Rigging Question
Posted: Wed Jan 02, 2019 2:35 pm
I started working on the WXB-F02 wing rigging and rear spar carry-through and I got to Step 17. Up to step 17 (after completing steps 8-11), I clamped the spar to the aft tunnel (via the shear plates) to ensure that the spar was sitting up against the aft tunnel. Once I drilled the aft tunnel to 1/2" (steps 14 and 16), I removed the clamps so that I could install the forward tunnel zee, wing attach angles and gussets. Once I installed the parts in step 17, I noticed that there was 3/32 of fore-aft clearance between the wing spar and the inside of the forward tunnel zee.
Is this type of clearance normal? I couldn't think of a reason for a gap that large, and I didn't want to start drilling the 3/8" holes in the forward tunnel until I confirmed.
