Sonex B Tail Kit CCC/SSC Rivets
Postby pfhoeycfi » Wed Mar 28, 2018 1:25 pm
The tail kit came with a package of 10 CCC-42 rivets and a package of 10 SSC-34 rivets. They are on the inventory list as well. I cant find the call out on the dwgs. I emailed Sonex...ng...
As soon as I drill the wrong size hole I'm quite sure I'll find out where they belong.
Anyone have a clue what they are for?
peter
doylestown, pa
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Sonex B Tail Kit CCC/SSC Rivets
Postby Sonex1243 » Wed Mar 28, 2018 4:18 pm
I think they are for riveting the elevator horn to the ribs and the optional bracket if you go with the manual trim lever.
Oops, I'm not sure now as I used the normal rivets except for the nut plate in the horn for the trim cable clamp.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby Spaceman » Sat Apr 07, 2018 2:43 pm
I think the smaller -3x rivets are generally used for installing nut plates
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby lstinthot » Sun Jun 03, 2018 4:33 pm
If you look at page SNX-T07, they are to hold the nut plate on if you are putting the trim tab on the elevator.
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Postby pfhoeycfi » Wed Jun 06, 2018 10:39 am
lstinthot wrote:If you look at page SNX-T07, they are to hold the nut plate on if you are putting the trim tab on the elevator.
I think what happened was Sonex removed the tab from the B tail detail but didn't remove the rivets from the hardware package.
peter
building SNB0021
Peter Hoey
pfhoeycfi
Return to Sonex-B / Waiex-B
