Sliding canopy for Sonex/Waiex B
Postby Dareha » Sat Feb 20, 2016 12:14 am
Does anyone have ideas about a new sliding canopy for the new B models? I have never been a big supporter of the side flip canopy. A canopy that slides back allows so much more. Would the slide canopy used by the Sonex group still work?
Thank you
Darrell
Dareha
Re: Sliding canopy for Sonex/Waiex B
Postby wlarson861 » Sat Feb 20, 2016 2:14 am
I think you mean swing back. I don't know of a sliding canopy on a Sonex. I put a swing back on my Sonex that I field engineered mostly on my own. If the B Model uses a support structure the same as the original plans canopy frame then it would be very easy to convert. However, realize that the swing back is more weight and more work/time than following the plans. I accepted these conditions and am still happy with my decision to go the swing back route.
Bill Larson
N861SX
wlarson861
Postby DCASonex » Sat Feb 20, 2016 9:24 am
The straight sided fuselage of the B model does open up the possibilities for a sliding canopy.
Postby Ercoupechris » Sat Feb 20, 2016 10:16 am
Does anyone know the actual weight penalty in pounds for the flip back canopy ?
Chris Schuldt
703-928-5199
BRM Aero Bristell NG-5
"B" model Conversion Waiex s/n 64 4th owner, kit from 2007
Edge Performance 915-ECi 120 HP EFI with Ring Mount
Rotax iRMT Service
Rotax iRMT Maintenance
Rotax iRMT Heavy Maintenance
Ercoupechris
Postby wlarson861 » Sat Feb 20, 2016 1:10 pm
It's around 5 pounds or less. The three swing arms, right side latch and right wing walk are the parts added to the original design. I didn't weigh the parts prior to installing them so this is just a guess.
Bill Larson
N861SX
wlarson861
Postby fastj22 » Sat Feb 20, 2016 5:51 pm
I agree, no more than 5 lbs.
Postby Waiex 49 » Sat Feb 20, 2016 6:51 pm
I purchased the swing back canopy kit.
Haven't installed it yet. Will get to that project next winter.
The kit weighed in around 4 1/2 pounds.
Probably around another pound or so for the right side wing walk.
My opinion is that it is well worth the added weight, as I consider the side opening canopy a weak point in an otherwise good airframe design.
Waiex 49
Postby fastj22 » Sat Feb 20, 2016 9:12 pm
A sliding canopy would probably weigh as much as a swing back. You won't need the swing arms or the hinge points, but you would need three tracks. I think it would be better than the swing back though. I can't throttle above 1500 RPM with my swing back because it lifts the canopy off the back and bangs it back down. Both would be far more rigid in the open state than the tip over style.
Looking forward to seeing how B builders roll their own.
Return to Sonex-B / Waiex-B
