T41pilot wrote:I have the Turbo and my #3 is also the hottest. I'll be following your updates on this mod. Is this installed on both sides? I'm assuming at this point there might be a small drag penalty but quite frankly a mile or 2 an hour loss is well worth a cooler happier engine to me in my opinion. I'm currently test running the under cowl naca vent mod pointing some outside air at the aeroinjector to keep the engine from quitting at roll out after landing. Have only 1 flight with that so far so no conclusive result yet. My engine seems to be fine in other respects during the flight other than I have to cruise climb most of the time to keep #3 under red line. Once in cruise the temp comes down fine.
pfhoeycfi wrote:T41pilot wrote:I have the Turbo and my #3 is also the hottest. I'll be following your updates on this mod. Is this installed on both sides? I'm assuming at this point there might be a small drag penalty but quite frankly a mile or 2 an hour loss is well worth a cooler happier engine to me in my opinion. I'm currently test running the under cowl naca vent mod pointing some outside air at the aeroinjector to keep the engine from quitting at roll out after landing. Have only 1 flight with that so far so no conclusive result yet. My engine seems to be fine in other respects during the flight other than I have to cruise climb most of the time to keep #3 under red line. Once in cruise the temp comes down fine.
Yes, both sides. I have no prob with heat effecting the aeroinjector. My fuel line from the firewall to the aeroinjector is about 6 inches, if that, double insulated w firesleeve. No burbs, hiccups or stalls.
T41pilot wrote:I'm assuming at this point there might be a small drag penalty but quite frankly a mile or 2 an hour loss is well worth a cooler happier engine to me in my opinion.
T41pilot wrote:My engine seems to be fine in other respects during the flight other than I have to cruise climb most of the time to keep #3 under red line. Once in cruise the temp comes down fine.
