Single Pilot Operation with Center Stick Sonex or Waiex
Re: Single Pilot Operation with Center Stick Sonex or Waiex
Postby BRS » Wed Feb 15, 2023 8:17 pm
sean44 wrote:Brock,
Where are you located?
PM sent...
It would be trivial to take a small tubing cutter to the inside pedals and remove them in such a way that they could be sleeved and later reinstalled. Else you could just paint them red or wire them to your ignition coils to keep your feet off (kidding of course).
I believe you could contact Sonex and they would put together all the parts for the change from dual to single. I believe that is what I did. Basically replace (almost) all the parts in this pic (below). Then the seat pan would have to be patched and a center hole cut, this is what I did. Else you could get a new seat pan an hinges from sonex (more work, more expense).
I think that is most of it.
edit: One more, seat cushions. I started from scratch on mine since the old ones were not nice.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby sean44 » Thu Feb 16, 2023 7:38 pm
Perfect - thanks for your time Brock - very helpful indeed.
sean44
Postby Bryan Cotton » Thu Feb 16, 2023 11:41 pm
There's a center stick Sonex with a Jabiru on barnstormers.
https://www.barnstormers.com/listing_im ... 00679&so=9
Edit: nevermind, dual sticks.
Postby sean44 » Fri Feb 17, 2023 8:32 am
Yea I had to look twice also. I am thinking about getting a pre-buy on it and converting to center stick. Already talking with someone here who did the same thing. But this plane hasn’t flown in a few years.
sean44
Postby caveman371 » Fri Feb 17, 2023 9:37 pm
This was my set up. Throttle is on the left out of view
I’m 6 ft. 250. Very comfortable
caveman371
Postby Bryan Cotton » Wed Feb 22, 2023 5:58 pm
This center stick legacy Sonex just popped up in the classifieds here and Barnstormers.
https://www.barnstormers.com/classified ... Sonex.html
Edit: the former owner used to have a Pitts.
Return to Sonex-B / Waiex-B
