Hold off on putting the batteries in the tail until you run all your weight and balance calculations and you are for sure certain you need to do this.
The CG situation for my Viking Waiex was such that I needed to install the batteries in the tail. I can tell you that this is not an easy modification as the control mixer assembly takes up a good portion of the available space in the tail cone.
If you need to move your battery aft I would suggest locating it just behind the baggage compartment. If you need to move the CG further aft then add some ballast at the end of the tailcone between the stabilizers. The farther aft you move the battery the more difficult the job gets because you run up against the control mixer assembly.
If you do move the batteries aft, you might consider using the lightweight cable from Perihelion Design.
http://periheliondesign.comAft mounted batteries on my Waiex was one of the most difficult and time consuming aspects of my modification program. I would recommend you think twice before going this route. It can be done but it isn't easy.
Details on my web page.
http://www.mykitlog.com/donbowen
