by MichaelFarley56 » Fri Mar 28, 2014 4:00 pm
Sorry to hear about your issue there Roy. On a Sonex with the Jab 3300, this can also be an issue. I've seen a lot of people take the side of the battery box (normally the side facing out), cut that side off, and rivet hinges onto the edges. That way, when you need to remove the battery, pull the hinge pins out, remove the side of the battery box, and pull the battery out. You may be able to do that fairly quickly if you have some extra hinge material laying around and are okay drilling out those few rivets that are going through the firewall.
That's just one thought for you. As always, feel free to send the factory those pictures to see what they recommend.
Good luck and let us know what your fix is!
