Main wing bolt spec
Main wing bolt spec
Postby VillaAir » Sat Mar 09, 2024 5:03 pm
I recently found that I have 2 different lengths for the main wing bolts where the main spar hinges.
Anyone know what bolt is called out on the plans?
Greg
VillaAir
Re: Main wing bolt spec
Postby XenosN42 » Sun Mar 10, 2024 1:45 pm
VillaAir wrote:I recently found that I have 2 different lengths for the main wing bolts where the main spar hinges.
Greg
You'll find that on page ONX-W05; View A-A; Main Spar Pivot Hole
AN6-14 bolt (1 each side)
AN960-616 washer (2 each side)
AN310-6 castle nut (1 each side)
MS24665-285 cotter pin (1 each side)
Good luck with your new plane and the phase 1 testing.
-- Michael
OneX N169XE
XenosN42
