Alternative Onex Gear (Tail Dragger)
Postby WesRagle » Sat Feb 17, 2024 8:36 pm
Hi Guys,
I was cleaning out my email and came across a sketch of the Onex landing gear Steve Bennett built to give the Onex some extra ground clearance (+4"). The gear is heavier, both longer and thicker. Since O'Keefe Aero is now out of business I thought it would be OK to post the sketch before it's lost.
Note this statement from the old O'Keefe web site.
All gear is made from 2024-T351 aluminum and is 5/8" thick and varies in widths from 5" to 7" (Thanks Rusty).
Here is where the gear was first discussed.
https://sonexbuilders.net/viewtopic.php?f=21&t=1989&p=14798&hilit=gear+alloy#p14784
Note that it is advisable to add 2 to 3 deg. of extra bend at the bottom bend of the gear leg.
I used this gear and am happy with it. It gives the Onex a more manly stance ;-)
Don't know where to get axles since O'Keefe is gone.
Wes
Higher Resolution Steve Gear
Gear Leg
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Alternative Onex Gear (Tail Dragger)
Postby Scott Todd » Tue Feb 20, 2024 12:30 pm
I REALLY like the taller gear. I can't think of any engineering reasons to want one other that it will slow it down a little, but I sure do like the idea :) A nice tapered trailing edge could make up the drag difference. Hmm...I do have access to a 60 ton press...
Scott Todd
Postby WesRagle » Tue Feb 20, 2024 3:54 pm
Hi Scott,
For the taper I just copied what was done on the Sonex. Once I got the piece where I wanted it, I traced the profile onto a piece of hardwood, then I cut and fitted it between the gear leg and the fairing. I drilled, tapped, and counter sunk for one #8 screw to keep it from sliding down. It's been there ever since. More weight but ...
For final assembly I sleeved the brake line to protect it.
Polish or paint and your good to go.
Well, except for at the top of the leg.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby 13brv3 » Wed Feb 21, 2024 10:58 am
Thanks for posting all that Wes. I wish Sonex offered a taller gear, but honestly I don't think we'll see any updates to the Onex. I'm sure they kept the gear as short as possible to reduce the folded height, and because the Aerovee didn't need any more prop clearance.
Rusty
Rusty
Fixed wing, gyroplane, A&P
13brv3
Postby WesRagle » Wed Feb 21, 2024 10:34 pm
Hi Rusty,
13brv3 wrote:I don't think we'll see any updates to the Onex.
Sadly, I think you are right.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
