by fastj22 » Wed Feb 05, 2014 8:47 pm
1. Probably
2. Probably not. The Jab3300 is close to the Aerovee weight and lighter than the proposed Aerovee turbo.
3. Definitely not. the Onex has a vertical bulkhead. You will need to fabricate your own.
One builder put a Jab2200 in his Onex. He had to move the engine quite a bit forward for CG. This required a custom mount and cowl.
http://www.floridasonex.com/Featured.htmlI too like the folding wings.
I might still build a Onex as my next project. Or a Panther. But the D-motor looks enticing. So do the UL power plants. As does the Aerovee Turbo. And I have experience with the Jab3300. It will not be a stock Aerovee, not enough power.
As for LSA compliance, as long as you maintain stall and gross limits to LSA, you can always placard the plane not to exceed X RPM continuous power like the Carbon Cubs do.
