by 13brv3 » Thu Dec 09, 2021 11:44 am
I've been giving this some thought and if I'm unfortunate enough to have to replace the canopy at some point I may try it. The rear bow was plenty long as I recall, so I'd leave the front bow at the stock height, but raise the rear bow 1-2 inches. That would of course raise it above the turtledeck. You would then have to add a fairing of sorts to the top of the turtledeck to match the new canopy height. That might not be hard to do with aluminum, but certainly could be done with fiberglass. It might be aesthetically questionable, but it wouldn't bother me.
The stock canopy may not have enough extra extra material on the bottom edge, but I wonder if Sonex could arrange to provide one cut with as much extra material as the mold allows. I expect they normally cut them relatively close to the expected shape to make them as small as possible for handling. Worst case, the frame could be modified to raise the bottom edge of the canopy.
In retrospect, I probably should have made more of an effort to sit in one, and then I might have done this when I installed my canopy.
Rusty
Rusty
Fixed wing, gyroplane, A&P
