Onex Canopy Latch
Posted: Sun Jun 06, 2021 11:47 am
Besides my dumb mistake of ruining my canopy, here is a bit about Peter's latch based on Fritz's original design. Peter said this is the first one on a Onex.
http://www.ansoneng.com/sample-page/pro ... ety-latch/
Peter was great to deal with. I paid the extra for expedited shipping. I think it took about a week from Australia to USA. He was quick to answer emails and just pleasant to deal with. I've added a few photos that may be a bit large. His provided instructions were excellent. They were very detailed with photos.
The Onex canopy tapers pretty fast at the front. I cut the hook rail down but I could have cut it some more. You can see where the block hits the canopy. With Peters approval, I sanded the back at an angle to get it to fit. I took about 1/16 off at the forward edge tapering to nothing at the rear on about the top half of the block. He provided an extra little machined post to use as the grab point instead of the D handle. It worked well. I used the provided Countersink screw but it wasn't quite long enough. You can see it in the photos. Peter will include a longer one for future Onex kits. I'll replace mine with a local Hardware store one. I'll add another photo showing the block taper when I take it apart to replace the short screw.
The machining on the parts was excellent. The parts are polished and everything fit perfectly. The 3D printed plastic handle parts were well done. The locking part is VERY positive and solid. It will not move without pushing/pulling the button. If you have a high left handed throttle, it may interfere. Mine is on the right side so it wasn't an issue. Overall I'm quite pleased. My only critique is the Onex is supposed to be roughly an 85% Sonex. The exterior handle could be a bit smaller. Its looks rather large on the Onex. Its extra work for Peter but I'll buy the replacement parts when he gets them re-designed ;)
