Use of resistor for Tach pickup
Postby sidsx » Tue Apr 13, 2021 3:52 pm
Hello all,
I am in the process of installing the Aerovee engine and the the GRT EIS 4000 with the GRT Sport EX EFIS in my Onex I'm building. The question is rather I need to use a resistor if I'm getting the Tach input from one of the wires from the alternator? I would be interested in learning what others have done for their Tach inputs for the EIS.
Sid Essex
sidsx
Re: Use of resistor for Tach pickup
Postby WesRagle » Tue Apr 13, 2021 5:38 pm
HI Sid,
I used the resistor and the P-lead (per instructions) of a slick mag. Can't read RPM with the mag off. Just check "Mag Drop" by ear during run-up.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby sidsx » Tue Apr 13, 2021 6:48 pm
Thanks Wes...
sidsx
Postby sidsx » Sun Nov 28, 2021 5:43 pm
Should I expect to see engine RPM indication while turning the engine over with the starter on the Aerovee 2.1?
Sid
sidsx
Postby DCASonex » Mon Nov 29, 2021 10:27 am
The current pulled by the starter is likely to briefly but significantly lower your system voltage enough to render panel instruments inoperative or inaccurate.
Postby sidsx » Mon Nov 29, 2021 1:51 pm
Thanks David,
I would like to know if anyone out there with flying aircraft could tell me if they see rpm indication while motoring the engine with just the starter. I don't want to have to tear into the wiring after I have it finished so if I should see rpm indication and I'm not now would be a great time to know I've not wirer it properly. I have wired it IAW the GRT instructions but I don't see any rpm indications.
Sid
sidsx
Postby GordonTurner » Mon Nov 29, 2021 3:41 pm
Can’t really answer the question, but are you spinning with one set of plugs removed?
Postby sidsx » Mon Nov 29, 2021 8:10 pm
hi Gordon,
Yes it's with the plugs removed.
Sid
sidsx
Postby DCASonex » Tue Nov 30, 2021 11:15 am
The starters current draw is enough to cause my GRT Sport SX to drop out. If just testing on the ground, find another battery to run either the starter motor, or your panel instruments.
Postby sidsx » Thu Dec 02, 2021 12:43 pm
I'm not having any drop out issues everything else works fine I'm just not getting any rpm indication at all.
Sid
sidsx
