Auto Pilot in a Onex
Postby N21X » Wed Aug 26, 2020 1:02 am
Where is everyone installing pitch and roll servos in the Onex?
CFI, CFI—I, MEI, MEI-I, ATP, A&P
US ARMY Veteran
Rv9a - Flying
Rv3a - Flying
Onex #165 (Flush riveted w/AM 13 AEROMOMENTUM 127hp & a 59” 4 blade prop)
N21X
Re: Auto Pilot in a Onex
Postby XenosN42 » Wed Aug 26, 2020 4:27 am
N21X wrote:Where is everyone installing pitch and roll servos in the Onex?
I installed both about a year ago. The roll servo is installed on the right side (pilot's perspective) of the floor just forward of the main spar. (It could have been installed on the left side.) In that position it is out of the way and almost impossible to step on it or kick it.
The pitch servo is installed on the right side of the floor (pilot's perspective) just aft of the rear spar carry thru.
Here is an email I sent to another OneX builder who asked a similar question.
I took some photos of my roll servo installation. I couldn’t get great shots because it was difficult to place and point the camera in such a tight space.
https://jasflyer.com/cabinheat/Bell%20Crank.jpg The silver oblong piece in the middle of the picture is a bell crank I fabricated from 1/8" thick aluminum. It is designed to be connected to ONX-C03-10. When I made this piece I didn’t know how far below the pivot point the servo push rod would need to be connected. As you can see I drilled 4 holes. I ended up using the top one. The lower holes resulted in over control by the servo. So the lesson I learned that I can pass on to you is: your bell crank will only need to extend about 3 inches below the bottom of ONX-C03-10. I suggest you drill more than one hole, then experiment to find the one that gives you the correct servo/control response.
https://jasflyer.com/cabinheat/Roll%20Servo.jpg It was very difficult to get a good picture of this because the control stick frame (ONX-C03-03) blocked the view. (In practice this is a good thing, because the control stick frame also covers and protects the servo from being stepped on!) You’ll want to place the servo as far right as possible. This provides the best geometry for the servo push rod. Also place it as far back as possible. Keep in mind where the electrical connector is. I had a devil of a time screwing mine in because it is so close to the spar.
I custom designed and fabricated the servo mount tray. It has three sides and no bottom. The servo connects to the front of the tray using the mounting hardware that came with the MGL servo. At the bottom of the three sides are ‘feet’ bent away at a 90 degree angle, which are then riveted to the fuselage floor.
I’d estimate it took me about 1 hour to fabricate the bell crank, 2 hours to fabricate the tray and another 2 hours to install the whole mess in the plane.
Let me know if you have any questions. Good luck.
-- Michael
OneX N169XE
XenosN42
Postby vhhomer » Sun Aug 30, 2020 8:07 am
Merle located the roll servo in the right stub wing on N362DV. I don't have pitch in it, but would recommend it if your going to fly any distance.
Vince Homer
vhhomer
Postby N21X » Sun Aug 30, 2020 11:33 am
Michael,
Thank you for the great info!
US ARMY Veteran
Rv9a - Flying
Rv3a - Flying
N21X
Postby N21X » Sun Aug 30, 2020 11:36 am
Could you send me some pics/details of the pitch servo you installed aswell? Have you flown the autopilot?
US ARMY Veteran
Rv9a - Flying
Rv3a - Flying
N21X
Postby XenosN42 » Mon Aug 31, 2020 8:20 am
N21X wrote:Could you send me some pics/details of the pitch servo you installed aswell? Have you flown the autopilot?
Hi,
I'll take a few pictures of the pitch servo installation when I go to the airport later on this week. Should be before Friday.
I installed the servos in N169XE last October and I've flown using it often. On a recent flight I just want to go up to relax and enjoy a cool, 100% clear day. The flight was about an hour and I had the auto pilot on about 95% of the time. That included much of the climb, and about half of the descent.
I have an MGL Discovery iEFIS. Once I figured out the correct configuration parameters the servos worked very well. If you have that combination AND install the servos as I did let me know and I'll send you the parameters, so that you can use them as a starting point.
-- Michael
OneX N169XE
XenosN42
Postby stroudj002 » Mon Aug 31, 2020 10:56 am
Here is how I attached a Garmin servo to the elevator idler arm in my Onex that I am still building.
Jim Stroud
archive (14).zip
(240.46 KiB) Downloaded 372 times
stroudj002
Postby stroudj002 » Mon Aug 31, 2020 11:09 am
Correct auto pilot pictures
stroudj002
Postby XenosN42 » Thu Sep 03, 2020 1:02 pm
N21X wrote:Could you send me some pics/details of the pitch servo you installed as well? Have you flown the autopilot?
Hi,
Here is a picture of the pitch servo installation. The servo is located just aft of the rear spar carry thru. This picture shows more detail about the mounting tray I fabricated. The roll servo uses the same tray.
-- Michael
OneX N169XE
XenosN42
Postby N21X » Fri Sep 11, 2020 10:46 pm
So I installed the pitch just forward of the idler, all good, just need to connect and ensure the arm doesn't overtravel.
I installed the roll servo forward of spar all the way to the right. Connecting to the control stick it seems that a problem would exist because the roll has both pitch and roll connected to the rod arm. Has anyone flown this setup and are there any issues?
US ARMY Veteran
Rv9a - Flying
Rv3a - Flying
N21X
