Hi George,
I too am very interested in Onex data. I'm just now getting to the point that I can start gathering performance data so I don't have much to offer. A lot of the data you are asking for depends on technique/calibrated air speed/density altitude/wind speed. At present I can't provide data based on any of those criteria. I have about 30 landings and they have all been different :-) I need to check my airspeed calibration first. I'll edit this post and add information as it becomes available. I hope others will join in.
P.S. I don't know why the columns won't display properly. I cut and pasted from a Word document and removed tabs and replaced them with spaces manually.
W&B
April 29, 2020
Data recorded with top longeron level
Datum 50.875 inches forward of wing leading edge (Spinner Tip).
CG Range 60.875 - 66.875 inches aft of datum.
Empty Weight includes 3 quarts of oil
Weight Arm Moment
Left MLG 309.5 53.25 16480.875
Right MLG 305.0 53.25 16241.25
Tail Wheel 24.0 198.5 4764
Total E.W. 638.5 58.71 37486.125
E.W. CG 58.71
Typical effect of temperature and pressure altitude on takeoff performance and climb rate (Koch Chart).
Typical take off distance (Tentative) Zero Wind seems to be about 1000 ft. at ~ 3000 ft DA. Right at the touchdown marking on the runway. Slow throttle advance and no technique :-)
