Mike53 wrote:Hi all.
Does anyone know why we are supposed to cut 2" off the probe? I didn't and am wondering if it has anything to do with the fact I can't get the led's in the control box to light up.
I have a GRT EIS and a Belite fuel gauge.
I didn't wire it an avionics shop did and his assumption is the control box is defective.Of course he obviously didn't test the system when he was finished the job.
Needless to say It's the last thing I need to figure out before inspection.
Mike53 wrote:Lots of Michaels here. I thank you both for your help.
I cut a hole in the floor and covered it with a plate so that if I ever had to remove the probe it would still come out .
To be clear I don't have a Belite fuel probe just the gauge . The probe is a Princeton.
Good to know i don't have to remove it and cut it down.
I will check for loose connections . I'm comfortable building a plane or anything else for that matter but I have always had a mental block when it comes to electronics,Thats why I had the avionics proffesionally done.
Thanks again.
