by Onex107 » Sat May 02, 2020 8:26 pm
I bought the least expensive tow bar like I used on my C-150. Nothing fancy, spring loaded to cover the two pins/nuts on the front wheel. I had to replace the axle nut with a castle nut so the cup would go over it. I used it on the front wheel axle bolt, head and nut. But, I know it's unusual but I started pulling the Onex into my standard T hanger head first. It works great. Drive it in, push it out. No need for a tow bar. It's nice to pull in under the raised door out of the sun and or rain. The Onex is short enough that it will go in both ways.
