vhhomer wrote:I removed the gear and found a hydraulic press.
vhhomer wrote:It would be very difficult to rebend the gear without removing it from the aircraft. The forces required to straighten the gear are certainly sufficient to damage the fuselage if the fix is attempted with the gear in place.
vhhomer wrote:I used a 20 ton Harbor Freight press....
