Jacking up a Onex
Jacking up a Onex
Postby Eckenroth » Sat Aug 17, 2019 5:39 pm
Since the Onex has the flat gear legs is there a way of elevating a wheel for maintenance without using a jack on the fuselage and without marring the paint on the leg.
Paul
Eckenroth
Re: Jacking up a Onex
Postby peter anson » Sun Aug 18, 2019 4:29 am
Do you have a picture of the Onex gear leg and axle? Something like this might be suitable. Image
It was made to fit Jabiru gear legs but will lift anything that has a square end.
Postby Eckenroth » Sun Aug 18, 2019 9:48 am
That looks promising. Is this a commercially available product or a one off. More info would be appreciated.
Paul
Eckenroth
Postby peter anson » Sun Aug 18, 2019 9:25 pm
Yes, commercially available. See http://www.ansoneng.com/sample-page/products-summary/jabajack/ but it only works if there is a flat surface or flat edge to lift against.
Postby Onex107 » Sun Aug 18, 2019 9:32 pm
I don't have any paint to worry about. I just clamp a set of vice grips on the strut and use a car jack under it.
Postby WesRagle » Sun Jun 07, 2020 11:48 am
Hi Guys,
If anyone has come up with a good solution to this problem, I'm all ears.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby WesRagle » Wed Jun 23, 2021 12:26 pm
Hi Guys,
Time flies. It's time for first annual. I would like to put fresh rubber on the Onex.
So, last call. Has anyone come up with a nice way to pick up a Onex (in the hangar) for maintenance? Maybe some sort of lift table?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Scott Todd » Wed Jun 23, 2021 12:44 pm
This is the only picture I could find right now. I find this Harbor Freight table indispensable. I originally bought it to move Pinball machines about 15 years ago but use it for lots of stuff. It makes putting Onex wings on a snap. A few towels, and jack it up high enough so only the upper tab engages. With the wing hanging off the table, its easy to jack it high enough to put it about 30 degrees folded and slide it right into place. I've done it myself dozens of times. It literally takes 5 minutes to put them on. Wiggle a little while dropping a bolt in and done. For Landing gear work, I use a 2x4 under the forward engine 'tabs' and jack it right up. I also used it like this for all the bottom skinning so I could move it to the comfortable height. They have gone up a bit in price but if it broke, I would go buy a new one immediately.
Scott Todd
Postby WesRagle » Wed Jun 23, 2021 8:12 pm
Hi Scott,
Thanks, maybe this https://www.harborfreight.com/1000-lb-capacity-hydraulic-table-cart-60438.html.
Just prop the tail, slide it under the main gear from the front, get down on your hands and knees and work the peddle by hand.?.?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Scott Todd » Wed Jun 23, 2021 11:19 pm
I have also used it sideways on the firewall edge. I don't know what capacity mine is but the 500 pound one might work just as well. You shouldn't have any problems working the pedal. I just know I like mine and wouldn't be without it.
Scott Todd
