Gap seals
Gap seals
Postby vhhomer » Sun Jun 09, 2019 1:44 am
Has anyone else put rudder or other gap seals on their Onex or Sonex? If so, what was the result?
Vince Homer
vhhomer
Re: Gap seals
Postby Onex107 » Sun Jun 09, 2019 4:40 pm
Any one interested in gap seals I'd be glad to send pictures of my Onex tail by email. It's a simple installation and I think it is effective. Besides, it stops all those questions about the large gap.
Edit 6/12/19 - Added Email contents and pictures:
I don’t have a very sensitive butt, but, I thought the tail was having problems staying behind the airplane. So I went ahead and added rudder and elevator gap seals. I makes sense that the lift should be the same on both sides and with the hinge gap that wasn’t going to happen. The seal material I used was bought at a hardware store. It’s a roll of alum. About 12 in. wide that is normally used in the valley of a roof. It’s .010 thick coated gold on one side and the shiny side has a clear sealer on it that needs to be removed if you are going to polish it.
The seal is about 4 in. wide and has a row of holes on the inside edge to let the seal fit inside the spar and over the rivet tails from the rudder skin. I held it in place with a piece of 1/8 X 1 alum strip that goes behind the rivet tails and clamps the seal material in place. I had to put notches in the edge of the bar stock to let it seat behind the tails. Two or three rivets or screws hold the 1/8 bar in place. It can’t get out from behind the rivet tails so it doesn’t need a lot of fastening.
It helps to put a small crimp in the trailing edge to keep it straight and make it lie against the rudder. Mine does not follow the rudder through it’s full deflection. The tail behaves better now and the elevator seal had a bigger effect than the rudder. I had to add more down trim at cruise from the previous setting.
Edit 6/14/19 - Added elevator gap seal image.
Re: Gap seals
Postby GordonTurner » Sun Jun 09, 2019 5:34 pm
I’d like to see those pictures:
Gturner01@aol.com
Thanks, Gordon
Re: Gap seals
Postby stroudj002 » Mon Jun 10, 2019 10:28 am
Please send me the pictures.
stroudj002@yahoo.com
Jim
stroudj002
Re: Gap seals
Postby vhhomer » Mon Jun 10, 2019 10:48 am
I also would be interested in some photos.
Vince Homer
vhhomer@hotmail.com
vhhomer
Re: Gap seals
Postby Rofomoto » Mon Jun 10, 2019 10:50 am
I'd like pics also please
rofomoto@gmail.com
thanx billy
1735
Longassproject
Rofomoto
Re: Gap seals
Postby n502pd » Mon Jun 10, 2019 9:46 pm
Onex107 wrote:Any one interested in gap seals I'd be glad to send pictures of my Onex tail by email. It's a simple installation and I think it is effective. Besides, it stops all those questions about the large gap.
yep, add me to the interested in pictures list too!
nelsen.n502pd@gmail.com
thanx!!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Re: Gap seals
Postby Cess32cw » Mon Jun 10, 2019 10:31 pm
Please add me as well.
Markackerman2005@comcast.net
Cess32cw
Re: Gap seals
Postby onex28 » Mon Jun 10, 2019 11:02 pm
Hi Morrie, not sure if I could make it work with my wrapped rudder but please send me the photos. Thanks
mudywatr@comcast.net
onex28
Re: Gap seals
Postby 8pointroll » Tue Jun 11, 2019 8:09 am
Hi. Please ad me as well. Sonexn9sl@gmail.com. Thank you
8pointroll
