WesRagle wrote:HI Guys,
I am going for a budget panel for the time being. I am considering purchasing the Yaesu FTA750L. That will give me comm and a simple GPS for those occasional cross country trips. So, nav and comm for about $350. I intend to use an external antenna
Question: Is anyone else using a Yaesu FTA750L in the cockpit? Is the radio capable of xmit while charging? Do you receive side tone in the headset? Any comments regarding this radio appreciated.
I intend to use a GRT EIS. It's ugly, but it is affordable and it just works.
Question: Is there a pre-packaged system ready for a VW conversion.
I have already purchased a used ASI/Altimeter from Sonex LLC. The only flight instrument I need is a compass.
Question: Can anyone point me to a cheap little compass that will mount on the glare shield that you are happy with?
dirkverdonck wrote:Hi Wes,
As far as going cheap for now, this might be the wrong way to go as changing the instrument panel will be quite difficult afterwards if you leave the set-up as per plans.
I made the glareshield and instrument panel completely removeable and moved the panel backwards by 3" to create more room for wiring and instruments.
Bryan Cotton wrote:I replaced my fittings in my Waiex, reasoning was it is much easier before final installation. I did not do all the fittings, just the ones in the bottom.
kmacht wrote:For the compass, visit a local boating store. They have inexpensive compasses that are decent quality and are made to be tilted and turned at different angles.
