lgsievila wrote:Hi Wes,
I sent you a private message.
dirkverdonck wrote:Hi,
I measured my deck angle this afternoon and got 6.5°.
During the build, I moved the mounting point of the tail spring upwards so I could remove the bolt without cutting through the lower longerons. I also installed the 6" tailwheel assembly and all this resulted into a rather shallow deck angle.
Therefore, I cannot make a threepointer just above the stall speed because the tailwheel will hit first if the speed drops below 48 kias.
Planning to replace the 6" tailwheel with a 4" one soon iot to lower the speed during flare.
