Eckenroth wrote:I believe that the set screw would be needed to adjust the paddles parallel to each other and to take up space between the two when the wings are locked. By trying to do the space adjustment with the push rod would not accomplish the same thing. I want to adjust the set screw after final assembly and I can't easily access the hex drive without disassembling the paddle. I'm hoping that someone has figured out a method that is not apparent to me.
Paul
