Onex seat pan
Onex seat pan
Postby johnnn » Fri Sep 28, 2018 3:14 pm
Does anyone have experience in raising the seat pan in a Onex? I'm short and sit too low in my mock-up. John Onex 0179
johnnn
Re: Onex seat pan
Postby racaldwell » Fri Sep 28, 2018 3:26 pm
John,
Low is good. That way you can use thicker cushions to get the height you need and comfort level goes up to boot.
Rick Caldwell
Xenos 0057
racaldwell
Re: Onex seat pan
Postby merle reppert » Fri Sep 28, 2018 8:03 pm
I added a sheet of .025 from the bottom rear hinge to the spar ---Using hinges in both places ---Original
seat is not changed ---
i added
merle reppert
Re: Onex seat pan
Postby Onex107 » Sat Sep 29, 2018 10:56 am
I built mine to plan and sewed up a cushion/bag to fit the tapered seat shape and stuffed it with any material you want to use. It's about six inches thick at the center with a flat top. It puts my head about an inch away from the canopy with a head set on. That way you can also use a flat seat cushion of any thickness you want. I had my seat cushions built by a local upholstry shop. You get to pick the cover material, color, and type of foam rubber for the inside. And, it will fit a tall person in the future.
