Oops fitting on the (old) Onex tank
Postby SvingenB » Wed Mar 14, 2018 2:28 am
Decided to mount oops fitting, now rather than later. One 1/8 fitting for the fuel measurement tube, and one large for the fuel outlet. Has anyone done this, on the "old" tank with molded fittings? According to the instructions, the large oops fitting must be mounted straight down, vertical on the bottom, not horizontal like the molded fitting. It's impossible to see anything in there, so before drilling the 1 inch hole at the bottom, I would like to hear experiences from others. The molded fittings causes protrusions inside that may cause problems. (have already drilled for the 1/8 inch fitting)
Reserved LN-ENX for Onex #134
Onex build log
SvingenB
Re: Oops fitting on the (old) Onex tank
Postby DCASonex » Wed Mar 14, 2018 8:26 am
I made a pair of tools to smooth off the boss on the inside of the tank for the two sizes of fittings. Several people have used these and they are out with someone now, perhaps that person if reading this can send them on to you. With those is also a modified step drill that one of the users madea that makes drilling out the small fittings easier.
Postby GordonTurner » Wed Mar 14, 2018 9:00 am
I have the “OOPS” kit. G t u r n e r 0 1 @ a o l . C o m
Gordon
Postby SvingenB » Wed Mar 14, 2018 5:12 pm
Thanks, but I live in Norway, sending that tool across the Atlantic would probably cost a whole bunch :-) Could you describe more what it looks like, pics? and did you go with the outlet vertical ?
Onex build log
SvingenB
Postby GordonTurner » Wed Mar 14, 2018 5:16 pm
When i get home, presumably next week, i will photogragh the tools for you plus measurements.
I’m working on the sonex tank which sounds slightly different from Onex
Postby SvingenB » Sun Mar 18, 2018 11:13 am
Thanks, got those oops fittings mounted now :-) with some valuable info from David A.
Onex build log
SvingenB
Postby GordonTurner » Sun Mar 18, 2018 2:24 pm
Glad you got it going, sorry I wasn’t able to help. All the best,
Gordon
Postby inventor » Thu Sep 12, 2019 12:08 pm
Can anyone tell me what these "oops fittings" are and where I can get them?
Onex 150
inventor
Postby WaiexN143NM » Thu Sep 12, 2019 1:14 pm
hi guy
opps fittings avbl from sonex. look at the online web store. the origional tanks had molded in alum fittings, that over time became leak areas. new tanks no fittings, just drill a proper size hole and install oops fitings which seal by o rings.
Postby inventor » Thu Sep 12, 2019 1:34 pm
Yes, I have an old unused tank. Wish I knew the real name of the OOPs fittings.
Onex 150
inventor
