SonexN76ET wrote:http://www.mglavionics.com/html/velocity_singles.htmlI have the MGL Velocity Singles engine management system. This is less expensive than putting in VDO gauges and it takes up less panel space. I have been very happy with it. It is easy to set up, does not require a RDAC, and it has operated with no issues.
Agreed! I have the Engine 1 & Flight 2 MGL's in the panel and like the fact that I can retain a nearly "steam gauge" panel look and have excellent reliability and a lot of information. The only function I could not get to work correctly was the tach reading. I understand I'm not alone with that. But my install is on a Corvair so it may be different that others have. Really like the look:
FWIW,
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
161.6 hours / Status - Flying
