Forwad belly skin fit problems
Postby N814W » Sat Aug 19, 2017 3:43 pm
Anyone else have trouble with the cabin belly skin? I joined the fuselage today, and everything lined up shockingly well except the aft edge of the cabin belly skin. The whole row is a pilot hole's diameter too far forward...
C150 driver by day, OneX 204 builder by night.
Empennage done, fuselage in work...
N814W
Re: Forwad belly skin fit problems
Postby dhogue » Sun Aug 20, 2017 7:48 pm
I encourage you to contact Sonex Tech Support on this one.
because
I recently finished joining the forward and aft fuselage per the plans. The belly skin pilot holes lined up with no problem.
...AFTER one issue I did experience along that line:
...The lower cross-tie (that the fore/aft bottom skins join to the internal fuselage) was bent too low on the bottom bend so the for/aft and cross-tie holes did not align (by about pilot hole's diameter) but also the bottom skins could not mate flush with the bottom longerons.
Solution: I emailed Sonex Tech Support with an explanation and picture of the area of issue. They acknowledged the part was shaped incorrectly and replaced it with no problem in a timely manner. I have had a couple of other parts that did not match details in the plans and caused issues. Once I showed Sonex, with pictures and descriptions they were quick to respond and replace them.
Hope this helps.
Don Hogue
WIP: Wings
dhogue
Postby N814W » Sun Aug 20, 2017 8:15 pm
Thanks for the feedback, Don. I've sent Kerry a message with pics.
So often I find errors in either the parts or the drawings, I never know when it's me or them with this thing...
Every other hole lined up. I rechecked side skin overlap at the top and bottom, both sides, and they're all at an inch give or take a 1/64". Even where the belly skin is cut for the tail cone taper is exactly at the seam. I was absolutely sick thinking I botched something major, but after checking, I'm pretty sure it wasn't me this time.
Thanks again for the feedback!
N814W
