Don_P wrote:Regarding splice plates, here's a very minor item you might want to look at: A couple of years ago, while working on the forward/aft fuselage splices, I found that the Aft Fuselage Floor Spacer (ONX-F21-10) was too thick. Unless Sonex has modified this part, it is still 1/8" thick. If you do the math, however, you'll find that the spacer should be 1/8" minus the thickness of the bottom flange of the Lower Cross Tie #1 (ONX-F19-05), which works out to 0.093" (or about 3/32").
