by Onex107 » Sun Mar 12, 2017 11:32 am
I experienced a cracked windshield before reading the small notice in the manual about it. Even a small drop will cause a small crack. I used black kitchen contact paper to add a shielded area around the hole. It's a couple of inches larger than the hole on the top side and tapers down to the front edge where it's wider. I don't use a funnel, just the cans, but I do stuff a towel in around the tank opening to catch any small drops. Two of my tanks have valves that let me position the tank before pouring. Two others are the kind with the spout stuck inside, and these I am able to aim the spout while tilting and hit the hole before it enters the tank. We tested the windshield material in gasoline and it does not effect it until you bend the test piece. The stress on the surface, caused by the bend, is relieved by the fuel and a crack results. I wonder if a little heat applied to the bent plastic would relieve the stress?
