F17 - Question/Issue
Postby opunui25 » Mon Jan 18, 2016 3:23 pm
I am working on F17 currently and have a question for the community. As you can see in the picture, F21-07R has an slant to it when attached. Both sides have the same (5/32) gap. When I look at the bend I made, everything looks like but I get the sense that this should be square to the vertical for later when "north meets south". Can I get some recommendations if this was my error that needs fixing or have others seen the same thing and it's less relevant based on something later in the build that I have not uncovered thus far. Thanks in advanced.
F21-07R
Travis Sales - N214TM (Reserved)
"Remember that a lone amateur built the Ark. A large group of professionals built the Titanic."
opunui25
Re: F17 - Question/Issue
Postby 13brv3 » Mon Jan 18, 2016 4:11 pm
Those brackets take a LOT of filing to fit properly. The vertical bracket should nest inside the larger bracket as shown, or at least I hope this is correct :D
Cheers,
Rusty
Rusty
Fixed wing, gyroplane, A&P
13brv3
Postby opunui25 » Mon Jan 18, 2016 5:40 pm
Thanks for the pictures. That shows me what I thought originally. I need to get F21-07 vertical in order to support the joining of the two halves. I pretty much thought that was the case but it never hurts to ask. :) BTW: What technique dd you use when filing the chamfer? Vixen files or a bench grinder?
opunui25
Postby 13brv3 » Mon Jan 18, 2016 6:51 pm
I used some really old Vixen files for the rough part, and a Scotchbrite wheel on a bench grinder to finish covering the shop with dust :-)
Rusty
Rusty
13brv3
Postby N814W » Thu Jun 08, 2017 11:13 am
Running into this exact issue myself right now. Simply replying to confirm Rusty's solution of adding a radius to the back of F21-07 plates to be a solution to the fitment and nesting. I've got one of them almost perfect, but it's definitely working.
C150 driver by day, OneX 204 builder by night.
Empennage done, fuselage in work...
N814W
