rslskd wrote:Thanks, David. I will give Tom a call (makes me curious why you guys are so circumspect about the topic, though).
Yep, makes me curious too. When you find out, let us know :)
As for leaving parts unriveted, I didn't see anything in the vert stab plans about leaving an option to add nav lights later, though I could have missed a note somewhere. I think some of those notes only show up after you needed to read them :-)
I think you're going to be pretty much own your own to leave access to any portion that you might need later, so you should probably firm up a plan for what you plan to install. I personally won't be installing anything in the tail, so I'm not leaving any access, or wiring runs. With the availability of 3 in 1 nav/strobe/position lights for the wingtips, I wouldn't consider installing any lighting in the tail. If you want an electric elevator trim servo, that would be something to consider, but you'll really be on your own for that mod.
For future upgrades you might want, just try to leave a way to install them easier. For example, I don't plan to have any lights initially, though I might add them later. When I build the wings, I'll drill holes in the ribs for the wiring runs to the wingtips, and install thin corrugated conduit with a pull string. Of course the Onex wing sections are so short that it's not as critical as with other planes.
Worst case, the rivets are pretty easy to drill out :)
Cheers,
Rusty
