Mike53 wrote:I installed as per drawings and had no problem,albeit there is very little room between floor and bleeder to work with, when bleeding the brakes.
SvingenB wrote:Mike53 wrote:I installed as per drawings and had no problem,albeit there is very little room between floor and bleeder to work with, when bleeding the brakes.
How did you get all the air out when the bleed outlet is at the lowest point? Do you have to pump like crazy, or do you fill it up from the bleeder?
