Onex Upper Cowl
Onex Upper Cowl
Postby JohnH » Tue Aug 04, 2015 10:19 pm
Has anyone experienced a problem with the top cowl fit? My lower cowl fits perfectly but the forward, top, left cowl overhangs the lower cowl significantly while the right side fits well. I am cautious of using too much "persuasion" to make it fit. Tech Support tells me it will be OK on the day!
Any suggestions/solutions?
John
Perth, Western Australia
JohnH
Re: Onex Upper Cowl
Postby Onex107 » Wed Sep 16, 2015 1:44 pm
I didn't have that problem, but, is your bottom cowl tucked in under the valve cover gasket flange or outside the flange? Mine are both outside and the top fits very well.
Re: Onex Upper Cowl
Postby JohnH » Fri Sep 18, 2015 8:53 pm
Thanks for feedback but I don't have the engine assembled/fitted yet, but will be done in the next few months and hoping that when the rocker cover cutouts in the cowls are done it will relieve some of the top cowl stress and make it fit better. Otherwise the bottom cowl fits perfectly.
JohnH
Re: Onex Upper Cowl
Postby onex28 » Mon Oct 05, 2015 11:39 am
Now starting on the cowling and have this question. Are the marked valve cover cut outs on the cowling halves the same for the Aerovee, Humml, Revmaster and Great Plains engines. Would like to hear from each of the engine owners of modifications if any. Thanks.
David
onex28
Re: Onex Upper Cowl
Postby dallen » Mon Oct 05, 2015 2:15 pm
Be careful with the cut-outs. They are not accurate. If I remember right they are marked correct for one side only.
dallen
Re: Onex Upper Cowl
Postby merle reppert » Mon Oct 05, 2015 5:03 pm
I would make a cut out in poster board that fits the rocker covers----then tape it to the front of the Fuse sides and mark it carefully---Take the rocker covers off -rough cut a hole for the rocker covers ---put the cowl under the template and mark --Cut smaller till it fits--
merle reppert
Re: Onex Upper Cowl
Postby onex28 » Tue Oct 06, 2015 8:36 am
Good advise Merle, thanks. I only have the canopy and cowl left and they seem to be the most challenging to my skill level.
onex28
Re: Onex Upper Cowl
Postby onex28 » Sat Apr 30, 2016 7:31 pm
Greetings John H, This week as I work on my cowl install I find that I have the same problem you experienced. All worked fine with the lower cowl although it is a tad narrower than my firewall. The right side of the top cowl fits as it should and the left front side overlaps the lower by about 3/8 inch. How did you resolve this fit? Also, did you have a gap at the windscreen?
David W
onex28
Re: Onex Upper Cowl
Postby Mike53 » Sat Apr 30, 2016 7:50 pm
Hi John .
Here is how I managed the cutouts.Spare valve cover required or a good trace cutout on bristol board.http://www.onexmike.org/cowling-upper-lower.html
Antoine de Saint-Exupery
Mike53
