Nav/Strobe Lights
Nav/Strobe Lights
Postby thomasjones42 » Mon May 25, 2015 10:24 pm
Has anyone had experience (good or bad) with any particular brand of Nav/Strobe lights. looking for any thoughts or recommendations.
Tom Jones
Van Wert, Ohio
Onex #0133
Tri-Gear
Engine TBD
thomasjones42
Re: Nav/Strobe Lights
Postby MichaelFarley56 » Mon May 25, 2015 10:31 pm
I installed the Aveo Powerburst LED Nav/Strobe light and couldn't be happier. Very light weight, almost no power draw, easy to wire, and I thnk they're only around $400. While I haven't flown at night when it's truly pitch black, I have flown late in the evening and get lots of good comments on how bright the lights are. I mounted them on wingtip standoffs from www.gaugepods.com and the combination has worked perfectly.
Just my two cents of course.
Postby nwawingman » Mon May 25, 2015 10:35 pm
Tom,
I am happy with my LED Aveoflash Powerburst units I purchased from Wicks for about $450.
http://aircraftproducts.wicksaircraft.c ... 01&dlpdf=t
Rick Wantz - Arkansas
Sonex 367 T/W AeroVee/Aeroinjector - Prince Elliptical Prop <361hrs
1st Flight 7/13 KOSHX3 Young EaglesX14
http://www.mykitlog.com/wingman
https://www.youtube.com/channel/UC2TNLK ... A63FvnPkNA
nwawingman
Postby wlarson861 » Mon May 25, 2015 11:31 pm
I have Aeroled lights and I am quite happy with them. At Oshkosh I got to compare the two in the exhibit area and the aeroled's seemed brighter. That year they were about the same price. Today I would go price as a primary concern as I don't think the performance is that great a difference.
Bill Larson
N861SX
wlarson861
Postby tljones42 » Thu May 28, 2015 9:29 am
Thanks everyone for your input.
tljones42
Postby Concorde » Thu May 28, 2015 3:40 pm
Any recommendations on the tail mounted strobe light ?
Thanks.
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby SonexN76ET » Thu May 28, 2015 4:05 pm
I have the Whelen Microburst III LED nav lights/strobes that have a tail light built into them. From behind they shine white. This setup is similar to that on the new Cirrus aircraft where there is no separate unit for the tail light. I believe several of the Aveo models also feature the built in tail light.
I also put a red LED beacon on my turtle deck for additional visibility. The red LED beacon comes on anytime I have the master switched on. This also helps me to remember to turn off the master. The current draw is extremely low with the LED lights.
The red LED beacon I have has a sister model that is white that is used as a tail light. That model is PSA ENTERPRISES MODEL 918 LED TAIL LIGHT TL918. It is $79 from Aircraft Spruce.
Jake
SonexN76ET
Postby Bryan Cotton » Mon Oct 26, 2015 2:16 pm
Does anybody understand the difference between the Aveo powerburst lights and the more expensive ones like the AveoFlashLP's? Also for those of you with the powerburst it looks like they have the aft facing white light in the wingtip lights, is this right?
Postby Sonex1517 » Mon Oct 26, 2015 3:02 pm
Bryan
The powerburst do have a white facing LED
For what it is worth, the FSDO did not approve my Sonex for night ops and one key factor in that was the lighting. Aveo can say what they want but they (per the FSDO) do not meet minimum specs for night flight.
As always, your mileage may vary.
Postby Bryan Cotton » Mon Oct 26, 2015 3:40 pm
So it would seem that my two choices for TSO LED nav lights are Whelen or AeroLEDs. My hangar neighbor has AeroLEDs on his Luscombe and he likes them a lot.
Users browsing this forum: Google [Bot] and 19 guests
