Tachometer selection
Postby Klimek » Tue Aug 19, 2014 10:52 am
To all who can help,
I am installing analog "steam" gauges in my Onex.
The problem I am having is selecting a tach that will work with both ignition systems through or with the toggle switches that are used for both the electronic and
magnetron systems.
Do I have to have 2 separate tachs, one small digital for one ignition and a primary analog tach? one connected to each ignition system?
The easy way out would be to install one small digital tach for each system..(cheating?)
How does this work? As I understand it, here are different pulses from different systems and the tach (or tachs) have to be selected accordingly.
Any and all help is greatly appreciated.
Frank
ONEX 090
Klimek
Re: Tachometer selection
Postby Sonerai13 » Tue Aug 19, 2014 11:22 am
Frank,
At Sonex we pull the tach pulses off the alternator rather than either ignition system. The alternator puts out 6 pulses per revolution. Find a tach that will work with that setup and you're all set.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby Sonex1517 » Tue Aug 19, 2014 1:28 pm
Postby Sonerai13 » Tue Aug 19, 2014 2:15 pm
Sonex1517 wrote:Here are some examples I found - not sure if they will work....
Robbie and Frank,
According to the downloadable instructions posted on these web links, any of these tachs should work with a 6 pulse per revolution alternator. You just have to set the "dip" switches to the correct settings. Check out the instructions under the "downloads" tab about halfway down each page.
Joe Norris
Sonerai13
Postby Sonex1517 » Tue Aug 19, 2014 3:33 pm
Thanks Joe!
Robbie
Postby Klimek » Thu Aug 21, 2014 10:58 am
Joe, Thanks very much for your help.
This has made my life a bunch simpler!
Frank
ONEX090
Klimek
