jcondon wrote:Appreciate the feedback but I don’t know if this issue is applicable to non-OneX models. The OneX untrimmed wing tip is 20” long, the original tip design was extended to provide sport pilot compliance for “fluffy” pilots. Are the wing tips on non-OneX models this long and unreinforced?
My RV-9A has similar wing tips but probably only 12” long and they ARE reinforced as most RV tips. I know an RV is not the same as a OneX but they are similar. I think many if not most of the OneX builders trim the tips down so when they are folded they will fit under a standard garage door so there probably aren’t too many data points out there regarding full 20” length tips and any problems encountered. I’m not just concerned about total failure and the tip coming off but also concerned about cracking and vibrations.
Anyway, I appreciate the input.
