Onex Rudder cable routing
Postby thomasjones42 » Sun Jun 01, 2014 9:58 pm
Has anybody had a problem with the routing of the right side rudder cable. As I ran mine today I find it sharing a frame hole with the elevator control rod and doing sort of a half wrap on the elevator control rod enroute to the final frame hole behind the seat. Not certain if I have missed something in the plans or what.
thomasjones42
Re: Onex Rudder cable routing
Postby onex28 » Sun Jun 01, 2014 10:30 pm
There have been revisions on the relocation of some of the routing holes. I simply put the holes and added a pulley so I had a run clear of the elevator control rod. I moved the first pulley to the outside of the first former and added a pulley in the vertical position to the next former. Pics on my PC that doesn't send. PM me if you want pics and I'll take some for you.
David
onex28
Postby onex0127 » Tue Jun 03, 2014 4:43 pm
I attached the elevator push pull tube on the inboard side, this gave me plenty of room for the rudder cable outboard.
Right side rudder cable
onex0127
Postby onex0127 » Tue Jun 03, 2014 4:48 pm
This is on with the elevator trim. It works
Right Rudder cable
onex0127
Postby onex0127 » Tue Jun 03, 2014 4:52 pm
I hope this helps
onex0127
