Sonex1517 wrote:Have you gone to the Sonex website to look over the plans revisions?
Chicagoland
N1517S reserved
Bryan Cotton wrote:On my Waiex I had a couple instances of things not lining up. I checked my parts to the plans. Found that I had a couple tail ribs (the left and right) second one in that were too long. Now I always check part dimensions when I have a fit issue.
jcondon wrote:Had the same problem on my HS about one year ago. I reported the issue to Sonex via email, see following:
The skin holes did not line up with the center HS ribs near the rear spar when the skin was cleco’ed to the rear spar. I had to add a .060 shim between the bent angles and the heavy angle that allows the HS to be attached to the fuselage. I can’t see anything I may have done to cause this misalignment and I think the 6 holes in the center ribs that attach the ribs to the bent angles, needs to be moved towards the rear of the rib about .060 inches to correct the misalignment.
Apparently SoneX has not yet made any corrections in this area.
Also; looks like you either have the front spar upside down or the left and right ribs swapped, can't tell which since I don't know if your picture shows the HS from top or bottom. Could be the ribs are mislabeled left and right.
Joe
