by onex28 » Mon Sep 15, 2014 11:11 pm
Hi Frank, thanks for the response. I finally used the the .373 dowel pin reamer (6 blade , 1 3/4"long cutting surface) for the AN 6 hole and a .376 reamer (6 blade, 2 1/2" long cutting surface) for the locking pin hole. I used a tap wrench to hand ream using lubricating oil. For the rear hole that I drilled to 1/4" andI progressively up drilled using O, P, Q, R, S, T and U drills before reaming. I finished the left wing today and there is absolutely no play or wiggle in the connection. I hope my right wing finishes the same. In my opinion, hand reaming is the way to finish the holes, much more control.
Yes my spar was prebuilt. I'm not able to work on the plane year around (because I'm old and slow and trying to be perfect) so I chose the prebuilt route. I hope to finish it next summer.
David
ONEX 28
N951X (reserved)
