Onex Speed Run...……
Hey David Onex #0028......here are some "numbers" that I am seeing with my Onex #0024.
I have the Hummel 2400 which is 85 hp and a Prince carbon fiber "P" tip prop 54x48.
WOT...3510 rpm gives me 162 mph IAS. Fuel flow is 5.6 gph at 3500. Oil temp 183 F...OP 69 psi
CHT's run 225 F to 240 F ......EGT's 1350 F to 1390 F during that speed run.
Engine monitor is an Electonics International CGR-30P.
I have some photos of the panel during that speed run showing these numbers but I don't know how to post photos on here......if you send me your email ad I can send you thoses pictures.
gdbaxter78@gmail.comMy Onex has the long wing tips, 5:00x5 tires and weighs in at 640 lbs.
One other note: There has been some discussion about the "Red Cube" transducer for fuel flow. According to Electrionic's International (the maker of the Red Cube)…..the "Gold Cube" is to be used for "gravity feed" fuel systems....the Red Cube MAY give inaccuate readings if used in that enviorment.......just saying FYI.
For my previous RV/Lycoming setup I used the Red Cube for that installation which worked well. I have the Gold Cube in my Onex.
Gordon.........Hummel 2400.......Onex 0024
