Wes's Onex #89
Re: Wes's Onex #89
Postby WesRagle » Fri Nov 15, 2019 10:06 pm
Thanks Guys,
Very motivating to hear *real* airplane noises.
I took care of one more thing I have been putting off.
Pretty terrifying, but in reality not bad at all.
I cut two over-sized holes in a towel, clamped the lexan in place, medium speed and light pressure and voila. I polished the opening with 600 grit.
The most painful part was paying for the hole cutter :-)
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Wes's Onex #89
Postby bvolcko38 » Sat Nov 16, 2019 10:53 am
Where does that oil line go to coming from the oil pump cover?
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: Wes's Onex #89
Postby lgsievila » Sat Nov 16, 2019 2:03 pm
Hi Wes,
If only you had known-
I would have carried one down in my suitcase when I come down to your hood to visit my daughter for Thanksgiving.
See you soon my friend!
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Re: Wes's Onex #89
Postby WesRagle » Sat Nov 16, 2019 6:08 pm
lgsievila wrote:Hi Wes,
Hey Loren,
Well, I didn't think of that :-) Looking forward to your visit.
bvolcko38 wrote:Where does that oil line go to coming from the oil pump cover?
Hi Bill,
The line runs to the bottom of a firewall mounted oil cooler. Had I explained to Scott what my plans were, *before* he built the engine, I think I could have had a neater installation. However, I didn't think far enough ahead so I just gritted my teeth and made the necessary run. The air to the oil cooler will be supplied by a NACA vent on the cowl side. I'll use the exhaust of the oil cooler for cabin heat.
Preliminary firewall layout. It didn't end up this way but you can see how the oil cooler is mounted.
Oil cooler as mounted.
This pic shows the air supply for the oil cooler.
A similar setup worked well on the Sonex so I expect it to work well again. We'll see.
I wish one of the guys that live in the permafrost region, and is having trouble getting enough cabin heat in the winter, would give this a try. And, instead of blocking off part of the oil cooler in the winter, just plum in a heat muff ahead the oil cooler.
Different subject:
I think I have an interference problem with my induction system :-)
Seriously, I have a question: Do any of you guys have a good feel for how much the front of the engine moves around?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Re: Wes's Onex #89
Postby Bryan Cotton » Sat Nov 16, 2019 7:50 pm
I don't yet. I suspect I'll know by how much damage my baffles take while running.
Re: Wes's Onex #89
Postby inventor » Mon Nov 18, 2019 12:05 pm
Did you build the oil cooler or is it an off the shelf unit?
Onex 150
inventor
Re: Wes's Onex #89
Postby WesRagle » Mon Nov 18, 2019 2:26 pm
inventor wrote:Did you build the oil cooler or is it an off the shelf unit?
Who's asking?
Ref. http://sonexbuilders.net/ucp.php?i=profile&mode=signature
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Re: Wes's Onex #89
Postby WesRagle » Wed Nov 20, 2019 9:42 pm
Hi Guys,
I'm still moving along (at a glacial pace).
I covered and installed the glare shield and fuel vent. I may regret the covering the first time I spill fuel but I shall endeavor not to spill.
I also did some final trimming on the cowl. Since nobody would venture a guess as to the movement of the engine relative to the cowl, I made a guess. 1/4" top and sides and 1/3" on the bottom for a firm landing. I'll just have to keep an eye on it to see if that's adequate. I will attempt a jam seal (form the back) around the induction tube using a block of foam. If that doesn't work I'll come up with something else. Maybe try a more refined approach once the plane is flying and I need something to do.
I need to order fasteners. I prefer quarter turn fasteners. I'm thinking of these https://store.skybolt.com/phillips-sk28s3-series-c1207.aspx. Any advice appreciated.
BTW, UPS just delivered a sheet of 0.016. Now I have no excuse not to attack the baggage compartment.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Re: Wes's Onex #89
Postby wlarson861 » Thu Nov 21, 2019 12:10 am
When I changed engines and cowl I used the Skybolt fasteners. The adjustable receiver is worth the higher price. I have had to replace a couple of the cams. The locking pin fell out of two of them, one I found and re-staked it in the cam and it has held. suggest buying a couple extra along with a good supply of the retainer rings as they will pop off from time to time.
Bill Larson
N861SX
wlarson861
Re: Wes's Onex #89
Postby WesRagle » Thu Nov 21, 2019 1:16 am
Hi Bill,
Thanks for the reply.
I have a couple of questions.
In a recent "Shop Talk" article Robbie Culver stated:
I used SkyBolt fasteners, which were not cheap but certainly are high-quality
quick removal fasteners for the cowling. I was slightly disappointed at the
supporting documentation for these, as installation instructions were a bit less
than expected. I figured it out, but not very quickly. There are specialized tools
required also, so anyone going this route please reach out to me for loaners.
That leaves me a little concerned.
Also, in the "Engine Swap" podcast Robbie said that his cowl spit out one of the fasteners in flight which he speculated was the cause of a ding he got in his prop.
Questions:
1) What are the specialized tools that are required for installation?
2) Which retainers should be used with the Phillips SK28S3 Series studs (ref: https://store.skybolt.com/retaining-rings-c1213.aspx)?
3) The thickness of the cowl haves is pretty uniform along the sides (where most of the fasteners go). So, what is the advantage of adjustable receivers?
4) When you say "the locking pin" are you referring to the pin in the end of the stud?
Thanks for Your Time,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
