Hi Richard,
sonex1566 wrote:What sort of cruise speed does your 3000rpm give you on your prop?
I haven't done the speed runs yet. I hate to guess but ... I don't think my speeds will be that much different from yours. 125 mph at 3000 RPM, 135 @ 3200, 145 @ 3400, and 155 @ 3600. I expected a little more but that's my initial impression.
Edit: Well, I did some GPS runs today and I didn't even get close to the above numbers. Initial testing shows:
112 at 3000, 123 at 3200, 130 at 3400. Seems my airspeed indicator is reading high. I was at 5000 DA and my indicated airspeed matched almost exactly with my TAS calculations as made by this web site: http://www.csgnetwork.com/tasgpscalc.html. WOT produced 3600 RPM and an indicated airspeed of 140 mph. Oh well, I built a draggy airplane. Still having a lot of fun.I did intend to get you an answer this morning but when I got to the hangar I found I had left my steno pad in Olney. Left my funnel too. What better excuse for another cross country :-)
For today's trip I flew like this:
1) Full throttle for takeoff and initial climb
2) At about 300 ft AGL throttled to 3200 RPM which gives about 1400 EGT and 750 fpm climb.
3) At 1500 ft AGL nose over for cooling and speed. Pitch for 350 CHT. Approximately 500 ft per min climb.
4) At cruise altitude nose over and reduce power to 3000 to 3200 RPM.
On the outbound leg I leveled off at 2500 MSL, stabilized at 3000 RPM, and checked FF. FF was 5.2 GPH. I then climbed to 4500 MSL and checked again. As expected (with the Zenith Carb) the fuel flow hadn't changed but EGTs were lower. I just had to make sure that would be the case.
Still a lot to learn about the airplane but having fun learning. It's uncanny, but a check of the flight log on the GPS showed 134 miles in 67 minutes. Looks like 2 miles a minute portal to portal is going to be the rule of thumb.
I do wish I didn't have to fuel through a hole in the windshield. I'm limited to 100 mile radius unless I want to risk a shattered wind shield.
BTW, the easiest way to pick up climb (besides diet and exercise) is cold air induction. Good for at least 100 fpm at gross, probably more.
Hi N190YX,
N190YX wrote:It is my understanding from several sources over the years, the latest being the documentation accompanying a SureFly electronic magneto I recently installed on my certified airplane, that advancing the ignition timing will tend to increase cylinder temperatures.
My understanding as well. I know from experience that retarding the timing will increase EGT. Whether it is smart or not, I want to keep my EGTs down to 1400. To do that I have to give up a little on CHT. The difference between 1 or 2 degrees advanced and 1 or 2 degrees retarded is very pronounced as far as EGT is concerned.
Listening to the guys that have lots of trouble free flight hours on VWs, the key is keeping them cool. So, I'll strive to keep CHTs down to 350 and EGTs down to 1400 max and 1200 to 1300 in cruise. Funny how fast the emphasis changes from speed to reliability once you strap the plane on for the first time :-)
Wes
